Adding a ground rod is optional
You don't have to add a ground rod. Simply run the mast ground to the existing electrical service ground. Even if it's a fairly long run, it's effective and accomplishes the goal of holding the mast at ground potential.
Then, install a coax grounding block near the existing electrical service ground. (Close enough to need no more than 10' of #10 copper wire to connect the ground block to the electrical service ground.) Run the coax from the antenna to the ground block... then into the building.
I strongly prefer to keep all of the above wire and cable outside the building.
