Recommend Do Not use the preamp and distribution amps at the same time in the antenna system.
All amplifiers add Noise to the signals , to much noise is not good for distribution through out the antenna distribution system , cause bad reception at the Tv's.
Over amplification can channels to pixilate and blankout.
Recommend use the preamp only.
_______
All , coax , connectors , splitters , couplers , etc. , through out the antenna system are suspect of being bad.
Recommend correct problems through out the antenna system.
