Old 16-Sep-2013, 3:21 PM   #5
wesmon
Solved!
AH HA! Solved!
Attempt 1)
I disconnected the VHF portion of the Clear Stream and made a jury-rigged mount for it. I mounted it perpendicular to the VHF tower. I had high hopes because this makes complete obvious sense, like why didn't I think of this? UHF aligned with UHF towers and VHF aligned with VHF towers. Nothing - UHF good, VHF nothing.
Attempt 2)
This was a shot in the dark. I thought maybe it was the RCA TVPRAMP1R preamp. I had the cable from the Clear Stream plugged into the COMBINED receptor on the preamp and the switch was set for combined mode. Now, I took the VHF output and plugged it into to VHF receptor of the preamp, left the UHF portion plugged into the other receptor, switched the switch to "not combined" mode, and BANG! Super strong VHF signal on all TV's!
SOLVED!
I'm not sure why the separating it did it but it did!
Thanks for the help.
wesmon is offline   Reply With Quote
