Old 5-Nov-2010, 3:35 PM   #11
Originally Posted by freetvplease View Post
Will I need to attach a ground wire to my antenna if the base of the mast will be inserted into the ground/dirt?
John
To properly ground the mast, you still need the appropriate grounding system. Placing the bottom of the mast into the ground does not fulfill the requirements under common electrical code requirements.
