Old 14-Sep-2013, 12:14 AM   #6
Amplifiers Are Not the answer to , bad coax , bad connectors , bad couplers , and etc. .
ALL , coax , connectors , couplers , and etc , are suspect of being bad through out the antenna system.
Before adding the amplifier in to the system.
To prove reception.
Connect a NEW matching transformer (balun) to the HD1850 antenna.
Connect a NEW continues length of RG-6 coax with the Compression type connectors on the ends of the New coax , not the old crimp type connectors on the ends of the coax.
Connect to the New matching transformer and run the New continues length of coax through a open door or window , direct to 1 Tv.
Do a Double Rescan.
________________________________
