Old 13-Sep-2013, 11:06 PM   #3
Above the roof in such a manner that the roof and building are not impeding and blocking reception in the directions of , all around the compass.
Install a Channel Master CM5016 All channel antenna aimed at about 147 degree magnetic compass direction.
Here is how to aim antennas. http://www.kyes.com/antenna/pointing/pointing.html.
Use a Old School magnetic compass to aim antenna.
_______
A antenna system amplifier is not required.
_______
A antenna rotator is not required.
_______
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels.
The tuner in the Tv Must Be a , ATSC , aka , 8VSB , Digital Broadcast Tv tuner.
______________________________________________________
Some digital Tv's will Automatic channel scan for cable tv channels.
Go into the Digital Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
The Tv -->Must Channel Scan for the , ATSC , aka , 8VSB , Digital Broadcast Tv stations channels.
Do Not channel scan for Analog Broadcast Tv channels.
If the Tv/s do not have Digital Broadcast Tv tuners.
Then can use a converter to convert Digital to be received on a Old Analog Tv.
Walmart has a Simple Digital to Analog conver box.
The RCA DTV-800B1 converter box.
______
If the Tv is a Digital Tv that lacks a Digital Broadcast Tv tuner.
Then can use a.
http://www.epvision.com.
or
http://www.channelmasterstore.com/Di...tm?Click=24424.
_______________________________________________________
Or Buy New Tv/s.
___________________
Last edited by teleview; 14-Sep-2013 at 11:02 PM. Reason: Clarify information and typos.
