Thanks for the info Dave and John.
I like the looks of the RCA ANT-751. With its smaller form
factor, it will fit easily in my attic. The larger ones would as well but
this will be easier to handle getting it up there. I am only going to hook
one tv now but a second may come down the road. Plus it comes with a mounting bracket.
I take it I have to get a 75 ohm coax cable as one does not come with this model. I see some cables are quad shielded. Is this necessary? Im not sure of the distance to my tv from where i plan to mount this in my attic. Will have to take a measurement. Im guessing it is less than 50ft, maybe 20-30 feet.
If it doesn't work well in my attic, then I could mount it to a mast out side with a chimney mount.
Thanks
