Back to the topic: I forgot that you want to feed two TVs. Get an RCA ANT-751 and aim it at the cluster of strong stations in your list. You should be able to feed both TVs with a simple splitter. If you have trouble with any of the stations in the green section of the table, then you will need a preamp mounted at the antenna.
