Old 9-Sep-2013, 6:50 PM   #2
If you own the outside walls and roof of your part of the condo , then here is the Federal Antenna Law that says Yes you can install a Broadcast Tv Antenna of any size above the roof so as to have reliable reception.
Hoa's are well aware of this Federal Antenna Law.
Many Hoa's keep their mouth shut about it or try to twist the law and make you believe that you can not install and use a broadcast Tv antenna outside.
One way a Hoa will try and twist the law is say that the small satellite dish size also applys to the broadcast Tv antennas.
The Federal Antenna Law clearly states that Broadcast Tv Antennas can be of any size so as to have Reliable Reception.
http://www.fcc.gov/mb/facts/otard.html.
The Federal Antenna Law also clearly states that you can place a Broadcast Tv Antenna on a patio or balcony that is part of your unit and directly under your control.
___
That said. The Tv signals are strong at your location.
A Small Antenna such as a , ANT751 or AntennaCraft HBU11 , mounted above the roof in such a manner that the roof and building are not blocking reception in the directions of , South East , East , North East , North , North West , and aim the antenna at about 135 degree magnetic compass direction , here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html , will receive Many Digital Broadcast Tv Stations/Channels.
___
If you have a patio or balcony that is toward the , ~ North East ~ then a ANT751 or HBU11 out on the patio or balcony aim at about 135 degree magnetic compass will receive Many channels.
Or try the mohu in a ~~ North East ~~ window.
Or a better indoor type antenna is the Terk HDTVi (not HDTVa) will most likely work better then the mohu.
Aim the antennas to the south east the best you can.
__________
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Resacn , http://www.wchstv.comDoubleReScanAlert.pdf.
_______
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennacraft.net.
_______
Last edited by teleview; 13-Sep-2013 at 10:34 PM. Reason: Clarify information and typos.
