Old 8-Sep-2013, 8:24 PM   #3
kalmana1
Thanks for the reply.
I never took into account that the antenna might not be good enough. When I look back at my analysis, the channels listed in VHF-HI have a similar noise margin to the UHF ones. Were you referring to the max gain that I can receive for VHF for my antenna or was it my antenna and something coupled with my analysis report that makes it worse?
I guess the next logical question that I need to find the answer to is: Will my antenna receive a sufficient digital signal for UHF and VHF channels? If yes, will I incur enough loss that I might need a pre-amp based on the signal strength I will be getting?
Andy
kalmana1 is offline   Reply With Quote
