Old 6-Sep-2013, 11:30 PM   #3
If you will like to try for the Chicago Tv stations , install the Winegard HD7698P antenna above the roof in such a manner that roof and house are not impeding and blocking reception in the direction of , South.
I recommend Do Not use any type or kind of signal amplifier.
Because the local Milwaukee Tv station signal strengths are Very Strong Signal Strengths.
And will most likely over load a any amplifier and cause worse reception on many channels.
These 2 amplifiers are designed to eccept strong signals and resist overload , however that does not mean that the amplifiers will not over load because of strong signals.
If you will like to ->Test<- reception with a amplifier , then 1 at a time , try the Winegard HDP-269 preamplifier and Winegard LNA-200 'Boost' XT amplifier.
Try reception WithOut a amplifier first.
___________
Digital tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , http://www.wchstv.com/DoubleReScanAlert.pdf.
______________________
The Local Milwaukee Tv stations/channels are easy to receive.
Aim a Terk HDTVi (not HDTVa) antenna at about 322 degree moagnetic compass direction.
Last edited by teleview; 11-Sep-2013 at 11:15 PM. Reason: Clarify information and typos.
