Old 6-Sep-2013, 10:51 PM   #3
Examples of REAL Channels that are transmitted and received and virtual numbers.
WCCO-TV REAL UHF Digital channel 32 , virtual number (4.1) , CBS.
KSTP-DT REAL UHF Digital channel 35 , virtual number (5.1) , ABC.
________________________
There should be no situations/problems with reception.
Evaluate / Check , again to make sure the antenna is put together correctly.
Aim the HD8200U antenna at about 25 degree magnetic compass direction.
Use a Old School magnetic compass to aim the antenna.
Do Not use any of the satellite system passive or active system componets with the antenna system.
Yes it is Ok to use the coaxes of the satellite system.
As a Test to prove reception , Connect a NEW Continues Length of Coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
No amplifier , Remove ALL parts of the preamps units , Disconnect and Remove the Preamp Unit , Disconnect and Remove the Power Injector , Disconnect and Remove the Power Supply.
No , couplers , No splitters , No coupler ground block , No nothing.
Run the New continues length of coax from the antenna through a open door or window direct to 1 Tv.
Digital tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , http://www.wchstv.com/DoubleReScanAlert.pdf.
Install the antenna above the roof in such a manner that the roof and house are not impeding and blocking reception to the , North East.
Last edited by teleview; 15-Sep-2013 at 12:28 AM. Reason: Clarify information and typos.
