Old 6-Sep-2013, 9:55 PM   #2
Have you tested reception with the antenna and preamp at 25' now that you're satisfied you have the antenna assembled correctly? The results can be dramatically improved when moving up that far.
There are several amplifiers in the Chromstar 2000 series. Which model do you have? Most of the model numbers look like "AP-8xxx" http://www.winegard.com/kbase/upload/2451964.pdf
