Old 5-Sep-2013, 8:55 AM   #21
cityfool
woah. that was an awesome tool. now the challenging part it that there are two strong signals but they are point about 60 degrees away from each other. LOL
But i think i will hit the main channels.
On another note, I did another sort of experiment with the antenna this evening.
So originally, i had a problem seeing channels with the c2 antenna on the tv in the living room. I was only getting 7 channels. So I thought what would happen if I connect the c2 antenna to a tv in the room farther back (where i had the RCA rabbit ears) and after i swapped the antenna...
A funny thing happened, rca picked up about 30 channels. c2 picked up about 60. LOL so i dont understand whats going on. Both tvs are on the same floor. and keep in mind im pointing the antenna in the same direction as i did with the first tv. odd.
thoughts?
cityfool is offline   Reply With Quote
