Old 5-Sep-2013, 12:48 AM   #14
olnick
Finally got the antenna up! couldn't get any ground wire over the long week end and had a ton of bad weather predicted.... So I waited until I had my groung wire!
Not too sure on the reception?? I went with the 91XG antenna feed into an RCA TVPRAMP1R combiner/preamp. I did NOT install the additional antenna. I tried to use my Sladco min/max signal strength meter to NO avail. The lowest signal it can detect is -20db. at any antenna position the best I could do was to have 2 different chanels # 9 and 34. I did better when letting the TV tuner do a search! Did I miss something?? I thought that I would have been able to pickup a"few" more stations than what I have. Ido get 5-7 stations. I have all the stations listed in an excell spread sheet. how do I attach a file for viewing??
Thanks
Nick
olnick is offline   Reply With Quote
