Old 4-Sep-2013, 7:10 PM   #1
csjenkins
Inconsistent receiption
Hello everyone!! I just cut the cable (literally) and am fully OTA now with DVD players to stream Netflix and Hulu.
I bought a MOHU SKY Antennae and placed it in my attic, running the single through the existing coax infrastructure in the house.
To my delight, the HD Insignia television in my bedroom got 38 channels from DC and Baltimore.
That said, I also have two Toshiba HD televisions which are only getting 6 and 11 channels respectively. On all three sets I am using the built-in Tuner.
I'm not very technical with this stuff. I would assume if one TV is getting 38 channels then 38 channels worth of signal are available to the other two as well. The biggest problem is that 38 channels are going into the bedroom, but only 11 into the main TV in the house. I'd just switch the two and forget about it, but there is a rather large size difference.
Any suggestions on what I should try? Would converter boxes boost the results? I did some direct testing between the antennae and the one getting 6 channels and shortening the path or giving it 100 percent of the signal didn't help.
Any suggestions would be appreciated. I am looking forward to my first month without a DirecTV bill!!! This is a great site and a tremendous resource.
csjenkins is offline   Reply With Quote
