Old 4-Sep-2013, 6:47 PM   #1
luvingthesun
Reception issues............HELP PLEASE!
http://www.tvfool.com/?option=com_wr...46ae0ea57b2751
This is the link to the analysis I ran. I am using a Clearstream 4 that I mounted to a Direct TV satellite pole. The antenna is then attached to the existing coax cable that the Direct TV dish was hooked up to. Additionally, I am using a splitter, which was also in place and used by the Direct TV satellite. Should I be utilizing an signal booster and what direction should I point it to get the best reception on all available channels that are in the "green" and "yellow" shaded areas? Any other suggestions would be greatly appreciated.
luvingthesun is offline   Reply With Quote
