Thread: Fine tuning
Old 4-Sep-2013, 8:12 AM   #2
Questions...
The short answer is, you'll need to try the 91XG to know for certain.
Given that your TV Fool report is flagged: "WARNING: Address was only resolved approximately and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates.", it's uncertain if the data actually reflects the conditions at your location.
When generating a TV Fool report, my preferred method is to open the Interactive TV Maps tool. Leave the 'input method' set to the default, 'address'. Then, enter only the Postal Code, and then click the 'Map This' button.
At this point you should have a map displayed, with a movable cursor located at the center of the Postal Code that was entered. Use your mouse to drag the cursor to the exact location you're interested in. In the upper right corner of the map you can select from four view types, I find it helpful to have all four available... The Hybrid and Terrain modes seem to be what I use the most.
At the bottom of the map, enter the antenna height. You can also find the LAT/LON coordinates of the cursor (in decimal form, not deg/min/sec).
Once the cursor location and the antenna height are set correctly, click on the 'Make Radar Plot' button located at the upper right corner of the map. The TV Fool report opens in a new tab or window. You can then copy the URL from the address bar of your browser, for posting to a thread.
I hope this helps, I just want to be sure we give you advise based on the actual conditions at your location.
Is the existing antenna pointing toward the 'forest'?
Are you willing to 'test' reception with the antenna outside, clear of the obstruction caused by the attic/roof construction materials?
What call sign(s) is(are) added when you use two amplifiers?
What's the total length of cable from the antenna to the TV on the longest run? Are there any passive splitters in line? If so, how many output ports, and are there unused ports with no termination?
