For shot at reliable reception.
My recommendations are still the same.
When setting up and testing the system , leave the antenna clamps a little loose , tip the front of the antenna/s up so the antenna is pointed at mountain ridge.
When is all adjusted for best reception , then can bend the mast pipe and tighten every thing.
Tv antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate , and Will Be Domestic issues about the direction the antenna is aimed.
Remote control A/B antenna switching Is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
