Old 4-Sep-2013, 12:12 AM   #13
cityfool
Sorry for double posting but i did a search and I couldnt find the answer and I want a definite answer but
SO i was thinking what the difference was between antennas being mounted on the roof as opposed to letting it sit in a room facing the proper direction. the obvious answer comes to mind is that there might be obstruction between the signal source and antenna. So mounting it on the roof would make it so that there is less obstruction correct?
BUT if i just set up the antenna and face in the right direction next to the window and I do receive a strong signal with the intent to split it to two or more tvs, would it make a difference between being on the roof and the room?
I know it seems like a basic question but I figured it might save me a trip to the roof as well as extra mounting supplies if this method works...
cityfool is offline   Reply With Quote
