I'd 'test' reception outside, clear of the reception impairments of the attic. However, I want to respect your desire to make the attic install work.
Have you tried mounting the VHF dipole of the C2-V separately? You can add an extension cable if needed. I would continue using the UHF/VHF combiner that is included with the C2-V. Be sure the VHF/UHF switch on the preamp is set to 'COMMON'. The idea is that you can then aim the UHF portion of the antenna independently from the VHF section.
If that fails to produce reliable reception, then step up to an Antennacraft Y10713 if it will fit. If space is tight, the Antennas Direct CS5 or Antennacraft Y5713 would still have more gain than a single dipole antenna.
