Old 3-Sep-2013, 3:07 PM   #1
wesmon
Help with a VHF channel in Connecticut
HI!
I just dumped cable and feel so relieved! I hooked up an antenna and get all the stations I want to very well (PBS, NBC, CBS, ION) except for one, ABC. I am having a problem getting ABC reliably on all of my TV’s.
Here are the specifics:
http://www.tvfool.com/?option=com_wr...46aef588a2040c
Anetnna: Antennas Direct C2-V-CJM ClearStream 2-V Long Range UHF/VHF
Amp: RCA TVPRAMP1R Outdoor Antenna Preamplifier – it is connected right to the antenna in the attic.
Cables are all RG6
Antenna is mounted in the attic of a two story house.
3 TV’s connected via 2 two way splitters
If I have the antenna pointed about 280, ABC does not come in at all but everything else comes in reliably. If I point it closer to 240, then ABC comes in on ONE of the TV’s (the TV with the shortest run) but not the others. A few of the other stations occasionally get noise like ION get some pixilation.
My uneducated guess is that I should get a dedicated VHF antenna and combine the signals. I’d rather not mount to the outside of the house.
The TV that get’s ABC is on a short run to the second of two splitters and is plugged in directly to a TV. The other two TV’s are plugged into a USB Tuner and a HTPC.
Thanks!
wesmon is offline   Reply With Quote
