Old 2-Sep-2013, 8:23 PM   #7
Before you spend money on another antenna, try the TVPRAMP1R. If you don't see KTVD after adding the preamp close to the antenna (3 to 6 feet of cable from the antenna to the preamp), a UHF only antenna is going to have trouble also. I'm not saying you should give up... just setting realistic expectations.
Is the 8200 already at 60' AGL? That's an enviable size tower or mast.
