I think the HD7697P is much larger than needed.
Consider the RCA ANT-751 roof top mounted. By going higher, you hopefully place the antenna further from the reflected signals caused by vehicles.
You're correct to spec 'No amplifier'. Some folks struggle with low signal strength... That's not going to be the case for you. Most, if not all amplifiers will be overloaded with the strong signals you're facing. And if you could find an amplifier that doesn't overload, it would very likely cause your tuner to overload.
The copper clad steel messenger wire found on certain types of RG-6 is intended for use as a mast grounding conductor. In fact the NEC 810.21(H) specifically endorses 17 Ga. copper clad steel or bronze as a suitable mast grounding conductor.
