Old 2-Sep-2013, 7:31 AM   #6
Since I mentioned the LNA-200, I've been able to read of some first hand testing... Let's just say there are better options...
My personnel experience with the CM-3410 confirms it's a good low noise amplifier capable of handling strong signals without overloading. So as I said in post #2 of this thread, "If you connect one TV and get good reception, but loose some channels after adding the splitter, add a Channel Master CM-3410 distribution amplifier between the antenna and splitter. The amplifier is going to do it job best if located close to the antenna."
