Two antenna can share the same mast. It's usually best to place the UHF antenna at the top and the VHF or multi-band antenna 3' or more below. That implies that a 10' mast would be needed.
Are you already using the 8200 for reception of the local group of signals to the SW... And trying to add just KTVD to your line-up?
