Old 1-Sep-2013, 6:16 PM   #1
TVTomFool
Planning antenna install in Pittsburgh
I am in a residential neighborhood in the city and can receive most of the green channels (10miles or less) with a small flat set top antenna on the third floor. This is with the antenna next to the window.
report:
http://www.tvfool.com/?option=com_wr...46ae1d675fe430
With the TV and set top antenna on the first floor the reception is not good and when a car drives by the picture drops.
I'm thinking about installing a roof top antenna mounted on the chimney. I have a large oak tree in the backyard that is ~15ft higher than the roof and ~30ft from the chimney. The tree is on the West side of the house, the chimney is on the South side of the house. The houses in the neighborhood are all about the same height. There are two churches nearby that rise slightly higher than my roof.
Would the Winegard HD7697P be a good choice (no amp, no rotator, with 2 or 3way splitter)? The cable would run to the basement and split there to the 1st floor and maybe back up to the 2nd and 3rd floors.
For grounding the mast can I use the included messenger wire that is bundled with some RG6 cable or do I need to run a separate ground? I have an existing grounding block for the coax.
TVTomFool is offline   Reply With Quote
