Old 4-Nov-2010, 4:40 PM   #3
HopDevil
Thanks John
I don't need the rotator if I only point it in the south direction to pick up most of the channels in the green zone correct? After some thought, those channels in the green zone are the only ones we will need. Could you recommend a set top antenna?
Would it be worth it to try a set top antenna first to pick up the strongest channels? Or maybe a antenna in the attic? It would make things cheaper with a set top or attic mounted antenna.
Thanks
HopDevil is offline   Reply With Quote
