Old 1-Sep-2013, 3:51 AM   #10
Damon459
You're describing a situation that's quite common. Most TV signal meter functions display a value that's related to the error rate of the received signal. Simply increasing the signal level will not change the error rate if the errors are the result of signal quality at the antenna. A more powerful mix of signal, noise and interference will not be much easier to receive and decode than the weaker version.
If you get no signal through the preamp, you can presume the amplifier is not connected or powered correctly or it has failed internally. That you see signal though it says that it's working.
If the total length of coax is 50' or less, and you are only connecting one TV with a good quality tuner, a preamplifier will add little. A 100' section of RG-6 will have less than 6 dB loss at the highest UHF frequency. At VHF frequencies the loss can be less than the amount of noise created inside a good preamp.
So it sounds like I shouldn't be using one at all then? I'm only connected to 1 tv and have less then 25 feet of brand new RG 6 cable, being in a trailer house I didn't need a long run from the roof to the tv.
Damon459 is offline   Reply With Quote
