Old 1-Sep-2013, 3:25 AM   #8
Damon459
Amplifiers are not a replacement or substitute for the correct antenna, mounted in a location that has adequate signal quality. Signal quality is like water quality... There's a lot of water in the sewage treatment plant, that doesn't mean you would want to drink it. A weak signal free of interference and noise will be easier for a tuner to work with than a bunch of amplified noise and interference with a dab of real signal mixed in.
I realize that much, my main issue with the RCA pre-amp is I have no way of knowing if it's actually working. I set my Antenna up without the preamp installed and the signal difference was almost not noticeable. So how would a person know if the RCA one is correctly working or defective? At least with the winegards I have seen they have a light, and an actual testing procedure to tell if it's doing anything.
Damon459 is offline   Reply With Quote
