Soap Box Alert...
Amplifiers are not a replacement or substitute for the correct antenna, mounted in a location that has adequate signal quality. Signal quality is like water quality... There's a lot of water in the sewage treatment plant, that doesn't mean you would want to drink it. A weak signal free of interference and noise will be easier for a tuner to work with than a bunch of amplified noise and interference with a dab of real signal mixed in.
