Old 1-Sep-2013, 2:26 AM   #6
Damon459
If someone wants to experiment with the Stacker, I won't try to stop them. The HD Stacker has it's fans and some others who would rail against it. I've yet to find credible documentation of it's performance, so I'm inclined to recommend options that have published specifications.
I just ordered a TVPRAMP1R from Amazon... less than $25. http://forum.tvfool.com/showthread.php?t=13530
I'm not impressed with any of the rotators available... until you step up to commercial / HAM grade products. If the HyGain AR-40 is within your budget, I could suggest it in good conscience. http://www.hy-gain.com/Product.php?productid=AR-40
I'm more inclined to recommend a second antenna and tuner: http://forum.tvfool.com/showthread.php?t=2882 This solution avoids any risk of being stuck with a TV that has to be re-scanned every time you switch antennas or re-aim the antenna.
As I said I already have the TVPRAMP1R I bought it last month from Walmart it seems on but from what I saw it only helped according to my tv's signal meter by about 5 points. Now I know my signal meter on the tv probably isn't the best indicator since anything over 50 gets me a solid picture but thats all I have to go by. This is why I thought maybe a more powerful preamp would be better. As for adding a second Antenna, I think I'll wait and see if I can manage to pick up CBS, NBC, PBS with one antenna while I keep pestering the local ABC to add a relay tower out here. Thanks for the help.
Damon459 is offline   Reply With Quote
