The signal levels shown in your report suggest you need to use a large antenna with UHF and High-VHF capability or a combination of separate single band antennas.
Given the rather extreme terrain in the Missoula area, the accuracy of a prediction may be affected. Your reception experience thus far is encouraging.
Consider the Winegard HD7698P pointed at 314° per a real compass. If you have more than one TV to connect, or more than 50' of coax between the antenna and TV, add an RCA TVPRAMP1R preamplifier.
A premium system would be an Antennacraft Y10713, Antennas Direct 91XG and the TVPRAMP1R. Regardless of which option you choose, the antenna(s) need to be outside, clear of obstructions.
