Old 31-Aug-2013, 8:38 AM   #1
Damon459
Help in Western Montana.
Ok so here's the deal and this will be long. I started by using cheap bunny ears and picked up one station, so I though what the heck let's see what we can do with a better antenna. My first choice was the Antennas direct Clearstream 2-V long range UHF/VHF antenna, without doing a tvfool check. The results, I picked up NBC no problem which didn't surprise me since I can get that one with the rabbit ears, and if I angled the antenna at about 45 degrees I picked up ABC/FOX even though that one comes up as grey extreme measures needed. If I took out the angle I picked up CBS/NBC but lost ABC/FOX, and couldn't get PBS at all. So I decided to add the RCA TVPRAMP1R, this gave me a stronger signal for the above mentioned channels but again it was either CBS/NBC or NBC/ABC/FOX and no PBS either way. Next I tried the ClearStream 5 VHF Ultra long range and nothing at all, even with the pre-amp. I'm now using the RCA ANT751, which I understand is also know as the winegard EZ HD Antenna with the RCA pre-amp. I'm able to pick up PBS with a signal of 40 according to my tv screen and 70 for NBC, I can move it slightly and get CBS/CW as well but when do that PBS goes out. I know there is a spread between PBS/NBC and the rest of the stations, and probably can't get all the channels without an antenna rotator. So the main thing I want to know is it possible to get an Antenna that will at minimum pick up NBC,CBS,ABC,FOX or is what I have the best I'm going to get signal wise? Here is my tvfool report, http://www.tvfool.com/?option=com_wr...46ae259b3338d1
Damon459 is offline   Reply With Quote
