Old 31-Aug-2013, 7:00 AM   #2
To take full advantage of the available signals I would opt for a full size antenna such as the Winegard HD7698P paired with an RCA TVPRAMP1R preamplifier.
You could try a Channel Master CM-4228HD which is much more compact. However, it's High-VHF capability is much more limited. If it failed to provide reliable reception of the signals on real channels 7 through 13, you would be faced with adding an Antennas Direct CS5 or Antennacraft Y10713.
