Old 30-Aug-2013, 1:13 AM   #5
Originally Posted by isufan View Post
Is it possible to buy too much of an antenna ? this one I have looked at in the past. http://antennaszone.com/channel-mast...3020-3020-100/
In cases where you are very close to a powerful transmitter, a large high gain antenna may be inappropriate and result in reception of too much signal power. You're not in that situation. In other cases, a large high gain antenna may be too directional to do a good job receiving signals from two or more directions. Again, that's not the situation you face.
The CM-3020 and HD7084P are in the same class.
