Old 29-Aug-2013, 9:26 PM   #4
The current Broadcast Tv stations/channels that are being transmitted and received in the , USA , Canada , Mexico , are ,
UHF band channels 14 thru 51.
Your location has receivable Tv station/channels in all 3 Tv bands.
Most of the signal strengths at your location are Weak Signal Strength.
Recommend install a Big All Channel Antenna above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , South East , West , North West , North East.
Install a Winegard HD7084P All channel antenna aimed at about 116 degree magnetic compass direction.
Use a Old School magnetic compass to aim the HD7084P antenna.
_______________
Install a Winegard LNA-200 'Boost' XT antenna system amplifier.
_______________
For 2 Tv's connected use a , Hollandelectronics , HFS-2D , 2 way splitter.
For 3 Tv's connected use a , Hollandelectronics , HFS-3D , 3 way splitter.
Buy the HFS splitters at soldsignal.
_______________
Here are places to buy antennas and etc. .
http://www.soldsignal.com.
http://www.amazon.com.
http://www.ronard.com.
http://www.hollandelectronics.com.
_____________________
Here are some strong and sturdy antenna mounts.
Use the , ronard(911) , 5 foot antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at solidsignal by typing , ronard(x) , in the solidsignal search box or buy from ronard.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broacast Tv Reception and so do buildings and other obstructions in the directions of reception including your own roof and house.
The Best Practice is to install the HD7084P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
____
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
___________________
Some satellite systems will accept and distribute antenna signals and some satellite systems Will Not.
To reduce and eliminate the situations/problems of antenna reception when connected to a satellite system.
It is best to Disconnect and Remove All satellite system passive and active componets such as and not limited to , multi-switches , multi-plexers , splitter , combiners , amplifiers , power injectors , power supplies , and etc. .
_______________
Yes the satellite system coaxes and other coaxes that are in/on the building can be used for the Tv antenna system.
_____________________________
Last edited by teleview; 29-Aug-2013 at 10:44 PM. Reason: Clarify information and typos.
