Old 29-Aug-2013, 7:15 PM   #8
...some Hoa's will try and twist the information in the web site and try and use it to stop you from install the antenna above your roof.
A common item for them to use is the 1 Meter size limit for satellite system antennas. Your TV antenna is not a satellite system antenna, and is not limited in size.
