Old 29-Aug-2013, 5:06 PM   #2
The current Broadcast Tv stations/channels transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable channels in all 3 Tv bands.
The signal strengths of the Tv stations at your location Weak.
Recommend install a Big All Channel Antenna.
Install a Winegard HD7084P All channel antenna above the roof in such a manner that roof and house are not impeding and blocking reception in the directions of , South East , North West.
Aim the HD7084P antenna at about 143 degree magnetic compass direction.
Use a Old School magnetic compass to aim the antenna.
__________
Install a Winegard LNA-200 'Boost' XT amplifier.
__________
For 2 Tv's connected use a , Hollandelectronics , HFS-2D , 2 way splitter.
For 3 Tv's connected use a , Hollandelectronics , HFS-3D , 3 way splitter.
Buy the HFS splitters at solidsignal.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.hollandelectronics.com.
http://www.ronard.com.
_______________
Use the , ronard(911) , 5 foot antenna mount.
Use the , ronard(4560) eave antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at solidsignal by typing , ronard(x) , in the solidsignal search box or buy from ronard.
________________
As always trees and tree leaves , plants and plant leaves , in the directions of reception , have a Negative effect on broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
The Best Practice is to install the HD7084P antenna at a location that has least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
________________
Digital tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do a Double Rescan to clear the tuner.
Disconnect antenna coax from the Tv.
Scan for channels.
Unplug Tv from power.
Wait a minute or so.
Plug Tv back in power.
Scan for channels.
http://www.wchstv.com/DoubleReScanAlert.pdf.
_____________________________________
Last edited by teleview; 30-Aug-2013 at 2:04 AM. Reason: Clarify information and typos.
