Old 29-Aug-2013, 12:46 PM   #6
radman3d
Thanks for all the info. I really do not have the option to move the antenna to the roof otherwise I would have done that in the beginning, housing covenants will not allow this. I am already getting something like 40 watchable channels. I get some channels very weak and I'm going to try the pre-amp to see if that helps with the weak channels. What I would like to know is if you think the Channel Master 7777 is a good one or if there might be a better one to get?
FTI: The link to www.kyes.com/antenna/pointing/pointing.html does not work.
radman3d is offline   Reply With Quote
