No. You have ample signal strength, enough to service hundreds of feet of coax. You'll need to work on quality of the signal. Most likely, your problems are due to the hill(s) in your signal path towards SF and you'll need to experiment with antenna height and location.
First, try to identify the specific channels/stations you'd having issues with.
