Old 28-Aug-2013, 9:36 PM   #2
The reception at your location is Weak Signal Strength , install a Big Antenna.
-->Many<-- channels will be received.
Above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , South East , East.
Install a Winegard HD7084P All channel antenna aimed at about , 116 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
_______
Install a Winegard LNA-200 'Boost' XT amplifier.
_______
For 2 Tv's connected use a , Hollandelectronics , HFS-2D , 2 way splitter.
Buy the HFS splitters at sollidsignal.
_______
http://www.solidsignal.com.
http://www.amazon.com.
http://www.winegardirect.com.
http://www.ronard.com
_______
Here are some strong and sturdy antenna mounts.
Use the , ronard (911) 5 foot tripod antenna mount.
Use the , ronard (4560) eave antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
_______
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on reception and so do buildings and other obstructions including your own roof and house.
The best practice is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
_______
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or ' Antenna Channels' , in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channels scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 21-Sep-2013 at 7:59 PM. Reason: Clarify information and typos.
