Old 28-Aug-2013, 7:06 PM   #2
For reception of ->Many<- USA and Canada Digital Tv stations/channels install a Winegard HD7698P antenna above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , South , South East , West.
Aim the HD7698P antenna at about 170 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
____________
Install a Winegard , LNA-200 'Boost' XT , antenna system amplifier.
____________
____________
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.amazon.ca.
http://www.hollandelectronics.com.
http://www.ronard.com.
____________
Here are some strong and sturdy antenna mounts.
Use the , ronard (911) , tripod antenna mount.
Use the , ronard (4560) eave antenna mount.
Measure the chimney and use a , ronard (2212) , ronard(2218) , ronard(2224).
________________________
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broadcast Tv reception and so buildings and other obstructions including your own roof and house.
Multi-path/reflections.
Absorbing the Tv transmissions.
Blocking the Tv transmissions.
____
The Best Practice is to install the HD7698P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
____
The Tv/s Must Channel Scan for , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channel' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 29-Aug-2013 at 7:18 PM. Reason: Clarify information and typos.
