Old 28-Aug-2013, 3:47 PM   #3
jeff92k7
Thanks, I appreciate the response. I think I will give the HBU44 a try.
After doing some more research, I happened to come across the channel master cm-3016 antenna. That is the exact same design and size as my current antenna. It is rated as a 45 mile antenna in their product details, but when you look at the technical specifications, the 45 mile range is only for VHF (high and low band). The UHF section is only rated for 30 miles. Since all the local stations that I want are 36-39 miles away, it seems that I don't have enough antenna for the job.
jeff92k7 is offline   Reply With Quote
