Old 27-Aug-2013, 10:47 PM   #8
elmo
Well dang. Sounds like you've been busy already!
If you have a splitter and it has unterminated connectors, you've got a situation that is probably zapping signal strength there. A cheap little barrel connector - female on both sides and it connects two coax cables together - would be better in that case.
And you know - you said you had dual coax - did you try the other coax? I'd guess you have have done that. I'd certainly give that a shot before pulling anything new.
