Old 27-Aug-2013, 9:30 PM   #5
The current broadcast Tv channels that are broadcast and received in the , USA , Canada , Mexico , are.
UHF channels 14 thru 51.
___________________________________________________________
The antenna that is on the pole looks like a antenna that is designed to receive the UHF channels 14 thru 51 the best.
Aim the antenna at about 162 degree maqgnetic compass direction.
Use a Old School magnetic compass to aim antenna.
If ,
KNTV-DT , REAL VHF high band digital channel 12 , virtual number (11.1) NBC.
Is not received well , then install this 1 antenna solution.
Install a Antenna Craft HD850 all channel in places of the UHF antenna.
If the preamp is a all channel preamp and is in working condition , it should be Ok to use with the HD850 antenna.
Aim the HD850 antenna at about 162 degree magnetic compass direction.
I will like to know the make and model number of the preamp.
For the preamp to function , the power supply , power injector , preamp , need to be connected.
All three componets of the preamp unit can be on the input side of a splitter or use a splitter that will pass power through one or more of the input and output ports of the splitter , if the power supply and power injector are connected on the output of a splitter.
In other words , for the preamp unit that is out close to the antenna to function , the preamp unit must have power.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv station/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digita Tv's will Automatic channels scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels.
Scan for channels.
Last edited by teleview; 28-Aug-2013 at 1:46 AM. Reason: Clarify information and typos.
