Old 27-Aug-2013, 1:22 AM   #4
The DB8e should have a bit more gain. It was engineered with the new UHF band in mind. Older designs had to cover UHF CH-14 to CH-69. Since the FCC reduced the UHV TV band to CH-14 to CH-51, the new design can squeeze a bit more gain out because it doesn't need to cover as wide a range of frequencies.
Still the difference is not extreme, about 2 dB.
