Old 26-Aug-2013, 4:31 AM   #20
Given the terrain between you and the LA transmitters and the distance to San Diego, it sound like you're off to a good start. My next step re. CW reception would be experimentation with antenna height and location.
I would try adding a passive 4-way splitter. If you see an observable reduction in reliable reception, then add a CM-3410 between the antenna and splitter.
