Old 24-Aug-2013, 7:34 PM   #3
If you have the right preamp at the antenna, you very likely have more than enough signal power to add a 2-way split.
What antenna (Make & Model)?
What preamp (M&M)?
What existing splitter(s) (M&M)
How many feet of coax is there between the antenna and the TV? (If there are multiple TVs, use the longest run.)
How Long would the coax run be to the new TV? (From the antenna through amp & splitter.)
