Update KLEW RF 22
Well, the 91XG is airborne. I need to fiddle with the aiming a bit more. KLEW on RF 22 has not locked. I do see flashing one bar regularly as well as the signal meter bounces between 0 and 27 (high side of weak). I don't have a preamp.
I have put the Weingard 7870 combiner in and the 91XG is now working in concert with the ANT751. The ANT751 is pointed at 83 degrees and is receiving all signals it did previously. K23HT-D continues to be received.
I also have a 10 db line amp in place right before where the coax splits to go to each TV.
I'll attempt to aim the antenna again tomorrow. Would a preamp be something that *might* work on the 91XG mounted on the mast to pull KLEW's signal up?
Cheers.
